devis devis
30 points
Posted on - 12/16/2012
Hi, I would like to know where I can download a nice slider to unlock for blackberry. Can you tell me what the best locker for Blackberry phones is? Is it customizable enough so that it will fit my needs? Please tell me more about this. Thanks a lot.
Need to have a slider to unlock for blackberry
Hi there Devis:
There’s only one slide lock application for Blackberry Phones by way of Blackberry Web Store. Here’s the link where you can download your Slide-lock Application for your Blackberry unit/phone http://appworld.blackberry.com/webstore/content/44434/?lang=en
And yes, this is a customizable application. You can either enable or disable it.
I hope you like it.
Thanks for posting your question here.
Best regards,
Hi Devis,
One of the best slide locker application for Blackberry is the "Slide Lock" app that can be purchased from the Blackberry Appworld. It works perfectly with touch screen and non touch devices. You can also customize how long the timeout will be for it to automatically lock and if another application is running, you can choose whether to enable the lock or not. With this application, you will be able to save more battery and establish security. I've provided a link for you. http://appworld.blackberry.com/webstore/content/44434/?lang=en
Hope this helps.Â
