owen korber
10 points
Posted on - 02/17/2013
I need a HDD reset counter bad sector software. I had to repair of the bad sectors of HDD surface.
The problem is CHKDSK type utility that mark the bad sector in the hidden files system.
I need this software to regenerate the surface and repair the bad sector.
Need a hdd reset counter bad sector software.
You can download HDD Regenerator for completely repair all your bad sectors on your hard drive. It have a great features but if you download as a trial version you can only repair the first bad physical sector of the hard drive. You can see how to use the HDD Regenerator at this link: http://hddreg.com/how-to-use-hdd-regenerator/. This will guide you how to fix the hard disk bad sectors as Administrator. Have a nice instructions that will help you.
Williamson Mellisa
see HDD bad sector is very difficult to remove i suggest do a window check
just open dos and write CHKDSK /R
this will repair your HDD but not sure
