Need help about silent hunter logbook
Hi guys,
Silent hunter is a wonderful mission game. I love it. However, I do not know how to use silent hunter logbook. Tell me when and how we use this logbook.
Thanks
Hi guys,
Thanks
The logbook can be accessed by pressing the function key F10 on your keyboard. Furthermore, you can also view it if you go to the Captain’s cabin. The logbook serves as a record wherein it tallies or records your crew’s victories so that you can see them whenever you like.
Hey. Mcray Madden,
As you do I also love the game Silent Hunter.
As you have stated above you need help with the log book of the game.
Well, no issues for that you just have to join a forum for that and you will be perfect with the Silent Hunter’s logbook.
I hope that this will fix your problem.
Thanks & Regards
Gillam Janetj
