Need help and assistance on how to repair avi with bad header
Hi guys, I am currently into audio video interleaved.
I am using avidemux software, unfortunately I have an avi that has bad header.
Can you teach me how to repair avi with bad header?
Is there still a chance to fix this error.
Thanks
Answered By 0 points N/A #196976
Hello jaycepierce,
Yes AVI bad headers can be fixed easily. What you need to do is download and install one of these software which I listed below.
Fix Player
Fix Player is an easy software to use for repairing bad headers. With Fix Player open video files which needed to be repaired. Time taken to repair the file will depend on the size and the number of errors.
Program checks for errors and problems in the file using its index. It neglects the detected bad frames and let you to save the output video file.  One important thing to remember is if you try to insert and repair a video that doesn't need to be repaired Fix player might crash.
Download Fix Player
Digital Video Repair
Digital Video Repair is very simple software that lets you repair damaged or corrupted AVI video files. It’s very easy software to use. What you need to do is load the video and the Digital Video Repair will display all the parameters like resolution, FPS, audio stream, etc. Just click “Check Errors” to view the errors and “Check & Repair” will tell you if that file needs to be fixed and if needed it will fixed the AVI file.
Download Digital Video Repair
Video Fixer 3.2
Video Fixer 3.23 is software to fix damaged video files. Apart from AVI files you can also fix DivX, .asf, .wmv, .wma, .rm and .rmvb files too.
Download Video Fixer 3.2
Thank you.
Rubi Sharlene
