Need help and suggestions to create a training register template
Hi guys,
I am currently into training management.
I have several question with this, how do i create a training register template?
Can you also suggest sites that would has video tutorial for this problem.
Thanks in advance.
Answered By 0 points N/A #153440
Dear Janis
Microsoft has some of the best database applications and spreadsheet that you can use to create a simple training registers.
You can use several databases that are available. MS ACCESS is one of them. With MS access, you can create tables, forms queries and even reports. It has key database feature such as unique key field, primary key, table relationships as well as data type such as date and time, text field, currency etc. The reports are automatically generated using the report creation wizard. With the wizard, you can select the data source for you report; either a table or a query. The queries are used fir data filtering with a particular field and a query string.
Another tool that you can use to create a training register is the MS excel that comes with the Microsoft office application packages.
Alternatively, you can download some student registration database applications to use in registering your students
Several websites provide this tool too. E.g. Active networks.
Best of luck
