Need help in Anime Studio
Hi friends,
I am creating lot of frame sequences for an animated character, by using Anime Studio and it will be used somewhere. So I am having lot of actions. I want to perform such actions from command line but presently I am able to do if from the main line.
Can I specify the actions through command line? Please let me know if I can add a key frame for all bones of specified bone layer, at the same time on a specified frame. Because I have to put ‘stop’ frame between the sequences on the mainline to block them from influencing the action of the following.
Kindly help me get out of this problem.
Jacob
Answered By 10 points N/A #120160
You can do that by using several scripts, and some of the notable scripts that I will recommend to you are the Mkelley Key Skeleton script which I will ask you to visit the thread below and have a look at it:
http://www.kelleytown.com/forum/animators/topic.asp?TOPIC_ID=194
You can also try the batch render, which works as follows: You will need to drag several .anme files on it, and once you have done that you will start the render.
One unfortunate thing that I have to tell you is that you will not be able to send some parameters when using the renderer, although it will be good if it were possible to render only certain layers or actions.
I will ask you to stick to the skeleton script.
Regards
Thompson Locker
