Need Help Application Error 0x000007b Problem
I want help fixing the application error 0x000007b problem that I am having while opening some games. I need help urgently. Guys please help me with this.
The problem you are facing is mostly because of some missing dll files. That must be train for the error. Try checking that DirectX and drivers are upto date. Then download the following file and run it-
For 32bit
For 64bit
If the problem is with a game that you installed, make sure your computer meets the requirements. Check the specifications of the game to learn if your operating system is supported and if your machine can run it. The most important device with games is the video card and most of them have a high requirement on this part.
Make sure to check the amount of video RAM the video card should have in order to run the game. There are also games that show a list of unsupported video cards so check if your video card is on the list. Aside from the video card, check if you have the amount of RAM required to run the game.
Also, make sure your sound card is working properly. Some games don’t run if you have a faulty sound card. If you don’t see any problem, try reinstalling the game.
Notifications
