Need Help Avast Antivirus Uninstaller Tips
I am using Avast antivirus on my PC but it had not been performing good lately and automatically some unwanted Windows are popping up. Guys please help me with Avast antivirus uninstaller. Thanks.
To uninstall Avast completely from your pc-
1. Download the Avast clear software from the link-http://files.avast.com/iavs9x/avastclear.exe
2. Start Windows in safe mode
3. Run the software you downloaded
4. Select the folder in which Avast is stored
5. Then remove it
6. Restart PC in normal mode
This is how it is done.
If you want to remove your Avast antivirus, you don’t need an uninstaller program because it can be uninstalled from the Control Panel and that’s the easiest way. Click “Start,” “Control Panel,” and then “Add or Remove Programs.” Select your Avast antivirus from the list then click “Remove” or “Uninstall.” When it asks you to restart, restart your computer.
Another way to uninstall the program is to use Revo Uninstaller. Download and install the free version. Once installed, start Revo Uninstaller then select Avast from the list. Click “Uninstall” then follow the instructions to remove everything the program created on your computer. Restart your computer afterwards. If you think your computer is infected, download Sophos Virus Removal Tool.
It supports Windows XP Service Pack 2, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It is the best tool to use to clean an already infected computer. You don’t need to uninstall your antivirus to use the tool. It works alongside any antivirus program you may have.
When you scan your computer and it detects a virus, remove it then repeat the scan until it no longer detects a virus.
