anonymous
7060 points
Posted on - 09/18/2011
I've been thinking about buying a new graphics card lately and I'm still a little lost. Basically:
I found GTX 460 OC 1280Mb 256Bit DDR5 NVidia PCI manufactured by Colorful for $250
Another shop which sells HD 6950 Cayman 2Gb 256Bit DDR5 Ati Radeon PCI manufactured by Digital Alliance for $300Â
or HD 6950 1Gb 256Bit Mini DP DDR5 HDMI Dual DVI (HD-695X-ZDFC) Ati Radeon PCI Exp.manufactured by XFX For $225
Would it be a good idea to go for the cheaper one? Do brand names really matter?
Any tips?
Which is quite irrelevant, but does a better graphic card result in faster rendering for design?
Thanks for the answer
samson
Need Help On Buying an New Graphic Card?
It is my believe that whenever buy, buy something really special. I mean a good quality product.
So my recommendation will be to buy a graphic card which has more features even if it is costly.
Brand name also plays an important role. NVIDIA graphic cards are known to be the best ones. AMD and Intel are the other ones who offer good quality graphic cards.
You can find information about some of the latest and best graphic cards by visiting this link
Download Link
First understand your needs and take time to research about finding the best products which suits you.
Motin
1. HD 4650 graphics card has 320 stream processing unit, anti elision and anisotropic filtering, accelerated video transcoding,1080p more upscaling video, dynamic contract, HDMI technology, it's performance is unique and HD 4650 1GB DDR2 Graphics card price $71.50 brand name Sapphire of Radeon HD.
You can buy the above mentioned graphics card within cheap rate. This graphics card is known to world-wide. You may have to do your graphic design with this graphics card.
There are also you can find XFX Radeon HD 4650 1GB graphics card in the nearest market. You may looked 2560×1600 pixel LCD monitor.
