Need help cause I can“t uninstall software
Hi everyone,
I recently installed cakewalk proaudio and now I can’t uninstall it.  I tried the option given in the start menu and doing it through the control panel but no luck.  Is there another way to fix it?  Below is the error message. Hope I will find luck in solving this problem here. Thanks
Error:
Unable to locate the log file 'C:PROGRA-1CakewalkCAKEWA-1CWPA9-1.1SU'.Uninstallation will not continue.
Answered By 0 points N/A #138162
Since you can't uninstall your Cakewalk via Control Panel. The best way to uninstall it is by using a third party uninstaller or force uninstaller, you could download them on the net. You could try Mighty Uninstaller.
Once you downloaded Mighty Uninstaller, run the .exe file to install it, and then after installing run the program  choose
Cakewalk Pro Audio on the screen, click uninstall and a wizard will pop-out. Just follow the wizard to completely uninstall your cakewalk pro audio.
Another program that could help you "force" uninstall Cakewalk is by using Revo Uninstaller, you could download the trial version here.
