jayson mars
90 points
Posted on - 03/25/2012
I have recently bought a router but I cannot connect it with my pc or the opposite can also be said. Need to know the process for my office use. I have having some serious loses due to this issue so someone should inform me quickly.
Please kindly someone instruct me about the basic procedure of using router.
Jayson Mars
Need help with connectivity problem with router
Hi Jayson Mars,
Setting up a router is pretty easy though it much depends on the brand or the model you have. Anyway, every model has its own manual. Besides the manual, it comes also with an installation disc to aid you in installing and in setting up your router. There is also another way of setting it up through its default IP address. Every router is assigned with an IP address from its manufacturer. Try typing 192.168.2.1 in your URL Bar. This is the default address for most manufacturers. In there, you can setup your router and its setting to setup a wireless or wired connection in your office. If it still won’t work, then go to the manufacturer’s site; there could be a detailed step-by-step process on how to set up your router.
>>Mathew Joni<<
lonesome
Most problem in installing internet networking is the router. Here is what you do, first be sure that your router is in the exact place in where it should be or say a stable place like a table. Second, connect your internet in the router and connect your router to your pc and turn them on. Third, configure your router by going to the browser and type this address http://www.radmin.com/facebook/ipscanner.php or http://192.168.0.1 which are mostly the web address for most routers then you can see a log in interface in which the details are provided in your router manual. After logging in you can change your info and by that you configure your router and surely internet will get through..
Have a nice day..
