Need Help To Convert PDF To CSV File, Not Xlsx.
Asked By 110 points N/A Posted on -
Hello all,
I want to convert a PDF File to an Excel file, but not in xlsx format. I want to change it to CSV format that I can open in MS Excel. Someone, suggest me an online tool to Convert PDF to CSV file.
Answered By 0 points N/A #92673
You can simply transform your PDF File to CSV Format using an online Tool known as Convertio. The URL to the website is
 https://convertio.co/pdf-csv/
The steps are very simple, like other online tools. The first step is to upload your PDF File to the webpage. You can use click on the “Upload” button or drag and drop the file on the homepage of the site.
After that, you will be able to save the transformed file to your Dropbox Account, or the Google Drive Account.
