Need help in converting html file to PDF
Hi.  I have a lot of HTML files that I would like to convert to pdf or doc file format.  I'm looking for a program or software in converting HTML file to PDF where I just enter the URL of the web page?  Need help.  Thanks.
Best Answer by Peter A May
Answered By 10 points N/A #159348
Hi Halton Roy,
There are two ways to convert html file to PDF. One is Desktop based software and another is websites.
If you use website it will be good because you have no need install any software and you can avoid the install process. You can html file to PDF at the website of Acrobat. Here I am giving this website but you should create a username and password first then you can access that website. No tension about money because this website is free to use.
Web link- https://acrobat.adobe.com/us/en/acrobat.html
There is another way is desktop base software. If you think you have no connectivity of internet all time then desktop base software is best to use. It will be easy to you and efficient.
Download link: http://download.cnet.com/Winnovative-Free-HTML-to-PDF-Converter/3000-18497_4-10691753.html
How to download? Ok I am giving you a screenshoot it will you teach you how to download from this site-
Best of luck
Answered By 30 points N/A #159349
Hello Halton Roy,
As you want to convert your HTML files to PDF or DOC file format online,I suggest you a wonderful website for converting your files.https://www.html-to-pdf.net/free-online-pdf-converter.aspx.This is the link where you just enter the URL of web page and change your files format very easily.This is a very fast and reliable PDF generation website.You can also download the trial version of converter from this website but if you want to download complete version you must buy it.You can also create PDF reports from ASP.NET pages.You can add headers and footers in the document also.You can set the size of page, PDF compression level and page orientation.
