Here's my situation: I have access to a MSM 760 controller but I don't have a database server. I'm trying to use SQL Express as the database for guest management application 10 but keeps on having an error of "GMS cannot access database". Can someone help me in configuring this?
Need help in database for guest management application 10
Hello Tiffany A Toombs,
Here is the simple solution to your problem. Please visit the page mentioned below and read the complete thread. At the end of this thread you will find the solution to your problem, hopefully, and then you can configure it a lot more easily than before.
Using SQL Express for Guest Management
Post back to tell me if you found the solution or not. Thanks!
