Need help, does Symbian use mrp?
Hi! Can anyone tell me, does Symbian use mrp? Just interested in how they use it. Is it possible? Any ideas will be a big help. Thanks so much indeed.
Hi Kay,
The Mouse Recorder Pro is a powerful tool that saves records all mouse and keyboard inputs in any application and allow to repeat the recorded activities at any time.
MRP work on Mac OS X. Sits in the menu-bar and records your mouse and keyboard actions.
Features:
1. Mouse recorder (both movements and clicks)
2. Keyboard recorder
3. Precise speed and timing
4. Automatic updates
Particularly MRP does not work on Symbian but Advanced Key And Mouse Recorder work on Symbian. It’s a similar app like MRP.
Hope this would help you.
Thank you.
