saad kalwar
10 points
Posted on - 07/26/2016
Hello friends,
I own a Dell Laptop, which runs Windows XP on it. I have formatted the Computer, and now, I have lost the Ethernet Controller Driver. I am not able to connect to my LAN Connection.
Where can I download Ethernet Controller Driver Windows XP Dell?
Need Help In Downloading Ethernet Controller Driver Windows XP Dell.
Ethernet Controller Driver is an essential Component to establish a connection with a Local Area Network. You can download Intel Pro-100VE Network Connection Driver.
Visit this link.
http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=0V62P&fileid=2731107455.
After opening the Website, click on the “Download File” option to download the ZIP File. Now, extract the files and run the “.exe” file. Follow the On-Screen instructions to install the Driver.
If you lost your network card driver after formatting the hard drive and reinstalling Microsoft Windows, there should be no problem because you can always download it from the manufacturer’s website. If you have a Dell computer, go to Dell Drivers & Downloads. Here, enter your laptop’s model number, serial number, or service tag code then click to search for your product.
You can find it printed on a sticker on the side or bottom of the machine. When your product is located, click it to go to the download page. The page should detect your operating system automatically.
If the page shows a different operating system, click to change then select your correct operating system and then download and install all necessary drivers and software for your computer particularly the network adapter driver. Note: download all applicable drivers and software on your hard drive to serve as backup. The manufacturer removes drivers from the website regularly more particularly for very old computer models.
