Need help in Dreamweaver Instancebegin template
40 points
Posted on - 02/22/2013
Why is it that IE 7 crashes when I create a document using a Dreamweaver template?Â
My first line changes <!– InstanceBegin template="/Templates/default. dwt. PHP" codeOutsideHTMLIsLocked="false" –><!DOCTYPE html>.Â
I've tried this on Firefox and the line does not change.Â
Is there a workaround on this?
Need help in Instance begin template.Â
I'm using Dreamweaver 5.
