Need help Error Exporting application
Hi experts,
I have Android Phone and tried to connect my device with computer in order to export application but an Android IDE Plug-in error shows up saying “Error exporting application”. Can I get any tip to fix this problem? It would be really appreciated.
Android IDE Plug-in
Error exporting application:
Failed to export application
Answered By 590495 points N/A #184846
It seems the problem here is with your Smartphone software, the application you install on the computer so you can access your phone on your computer via the USB cable. The phone software also installs the necessary drivers for your phone so Microsoft Windows can better support your device.
Since you did not mention the model or the brand of your phone, try visiting your Smartphone’s manufacturer’s website and download the phone software. For users with ASUS Smartphone, download and install ASUS PC Link for Windows. Use the supplied password to unpack. It supports Microsoft Windows Vista and higher. It doesn’t support Microsoft Windows XP, OS X, and Linux.
The ASUS PC Link for Windows software supports the following ASUS Smartphone models:
  • ZenFone 5
  • ZenFone 6
  • FonePad 7
  • MeMO Pad 7
  • Fonepad 8
Aside from installing the ASUS PC Link software on the computer, ASUS PC Link also needs to be set up on your Smartphone. For more information on how to set up ASUS PC Link on your Smartphone, visit Installing ASUS PC Link. If you are using a Samsung Smartphone, go to Samsung Kies for Windows and OS X.
For Windows users, download either Kies or Kies3 depending on your phone model. Also, check the system requirements before downloading any of the versions of Samsung Kies.
