Hello guys. I need some help and tips on how to export crystal report to pdf format and have it directly saved at the local folder of our website and then have it as an email attachment sent viat SMTP. So far I have only succeeded in the conversion to pdf but couldn’t have it saved in the destination folder, and failed in the attachment via SMTP code too. Any ideas?
Need help to export crystal report to PDF format
Hi friend,
You can convert any Crystal Report to a PDF. This can help when you need to e-mail a report to someone who does not have Crystal Report. You must have Adobe Acrobat installed on your computer to export a PDF. You may download a free version of Adobe Reader from this site.
Using below method written in C#, you can export crystal report into PDF format and save it into physical location.
Private void exportReport()
//Create new report object
ReportDocumentcrystalReport = new ReportDocument();
// Load the crystal report
crystalReport.Load(Server.MapPath("~/Reports/Archive/ArchiveReport.rpt"));
// Assign a datasource for the report
crystalReport.Database.Tables["tblArchive"].SetDataSource(dtReportData);
//Show the report on the crystal report viewer
CrystalReportViewer1.ReportSource = crystalReport;
//Export to disk
crystalReport.ExportToDisk(ExportFormatType.PortableDocFormat, "E:\Report.pdf");
Now you have the PDF files saved on the disk and now you can attached it to a SMTP email. Try below links to see how to do a SMTP attachment
http://csharp.net-informations.com/communications/csharp-email-attachment.htm
https://www.codeproject.com/Articles/10828/Sending-Email-with-attachment-in-ASP-NET-using-SMT
