I have multiple monitors connected to my desktop computer, I m having troubles in switching between them again and again so I m looking for a batch file to change monitor, can anyone help me find such a batch file that can help in automatically switching between monitors?
Need help in finding the batch file to change monitor
Hello Clara,
Display Changer 12noon – http://12noon.com/?page_id=80 allows you to change your display resolution with the option to restore your previous resolutions. You can also set temporary or permanent multi-monitor setups.
PowerStrip – http://www.entechtaiwan.com/util/ps.shtm – This is a file that supports multi-monitor display that supports a large variety of graphic cards.
Winchel Shirlyn
Hi Clara,
You can automatically switch multiple monitors using a batch file. By using a different command line, it will allow you to change display mode on your computer. In addition, you can also opt to create a shortcut key into a shortcut file to switch multiple monitor. The link provided below is the detailed process on how to setup. Kindly click it and review and take note the process.
Switch batch file on multiple monitor – This is the detailed tutorial on how to switch multiple monitor using a batch file.
Ware
