Need help in Flowchart coreldraw
I'm having trouble using Coreldraw Graphics Suite X3. How do I add a node on a slanted rectangle in Flowchart shapes? The connecting line keeps on snapping. I need help in the basic shapes in Flowchart Coreldraw.
(a) Click on Rectangle Tool from toolbox and drag the mouse pointer to draw a rectangle.
(b) Click on it Select Arrange -> Transformation -> Skew. Enter a Horizontal angle and Click on Apply button.
(c) Select Pick Tool and Right Click on it and select “Convert to curves” or Press Ctrl + Q.
(d) Now select the Rectangle with the Shape tool from Toolbox.
(e) From the property bar, click the Add node icon . A new node will be added at the center of each side of the rectangle.
Patrickk White
Hello!
You can do it by following some techniques.
First, you have to click on toolbox's "Rectangle Tool" and drag the mouse pointer to create a rectangle.
Second, click on it and select "Arrange" > "Transformation" > "Skew". Then, enter a "Horizontal angle" and Click to "Apply".
Third, select "Pick Tool". Then right click on it and press Ctrl + Q. Now select the Rectangle Shape tool from the Toolbox.
From the property bar, click the Add node icon. A new node will be added at the center of side of the rectangle.
You can do it this way. Enjoy!
Notifications
