Need help in forefront icon
Please resolve this error : forefront icon missing in notification area. One day after turned on computer in the evening and the icon's wasn't there. Please resolve my issue.
Thanks,
Best Regards.
Thanks,
Best Regards.
First check whether any of icons are hidden by you unknowingly.
Right-click on the Task bar and select Properties.Click the customize button and window will appear showing the list of items which displays either icon is hidden when inactive or shown.
Then click on the items which you want to appear in the notification area, when done, click ok.
If the problem remains unsolved, try the below process and disable the Simple Service Discovery Protocol (SSDP) which discovers plug and play devices on your network. Â
Click Start->Run and type Services.msc.In the Services list, right-click SSDP Discovery Service, and then click Properties.On the General tab, in the Startup type drop-down list, click Disabled then click OK.
Hope the above information helps you better.
