Need help on choosing graphics card for gaming
Graphics card are mainly two brands make them NVIDIA and ati(amd) which chip or the gpu and there the boards are made by many brands like xfx asus msi gigabyte etc so as for gaming for a monitor 24 inch you don't need a power hungry monster card for this.
I suggest you buy mid range card brand xfx gigabyte to me good and for chip i prefer ati(amd) because they are bang for buck there are many models out there like HD series 5 and 6 which latest if you want good card for good price buy the ati HD5770 with gddr5 memory 1GB will be enough i think it helps your with your solution
If you want to watch from pc in a high definition than you must have to see that your Motherboard will support the high resolution graphics cards.
The best graphics card will be gigabytes 2gb.
It will give you the crystal clear pictures with a high resolution.
Good day I read your post its talk about of video card. Many kinds of video card in the market today, but you need to select the best video card to give a very nice graphics resolution. There are three types of video card likes:
Visit this site for more information:
Note:
Search the following type of Video Card to the website that I mention above.
Thank you hope it help.
Regards
jovhender
Hi Jimmyhimmy
Check out this Techyv post too to get more information according to your question.
