How to view recently viewed videos on youtube?
Asked By 110 points N/A Posted on -
I've been searching all files on my drive C, however I could not locate the directory where I can find those videos which I have viewed particularly videos from you tube.I want to use this video  for my  presentation in school,but I don't know how to save it. I was told that it is being saved by your computer in a specific folder, but I've searched it in the drive c,   however i really could not locate it. Can anyone help me with this one? I really need that video so badly.
Best Answer by android_baby
Answered By 0 points N/A #87581
May I ask if which browser are you using? Firefox? Opera? IE? Google Chrome etc…
Answered By 110 points N/A #87583
hi android, I'm using Internet Explorer as my default web browser, this is my only browser, i don't have opera, Google chrome esp. firefox which slows down my pc when it was once installed in my laptop. Can you give me a detailed instruction on how to save videos from you tube to my hard disk. Thanks a lot
Answered By 0 points N/A #87584
Try this link https://youtubedownload.altervista.org/
This software will allow you to save videos from youtube even while watching the video itself. It automatically detects videos from youtube every time you watch. hope this helps.
Answered By 0 points N/A #87585
If you are using internet explore, it must be located in the "so called" temporary internet files. It can be located using this
 C:UsersxxxAppDataLocalMicrosoftWindowsTemporary Internet Files
Or, you may locate it using the internet explorer-  (it's much easier 🙂 )
Now open your Internet Explorer.
Find Tools, then select Internet Options
Then, on general tab, you will see the browsing history, after that select the settings under the general tab.
Select view files. After that, you will now see all those video, pictures and other files which were saved by your computer in the system from your browsing history. Also, may i remind you that for you to be able to save videos from you tube, you must increase the size of you temporary internet files since videos involves large sizes. To do this, on the internet options, select setting on the browsing history, you will see "disk space to use"  click on that and increase the disk space (for me recommendable is up to 1GB) then press ok. That's it, Enjoy 🙂
Answered By 110 points N/A #87587
@Android,
I saw the file, thank you so much. And by the way, how can I save the file. I tried playing it in WMP, and it worked. Can I just leave it inside that folder so just in case, I will need it again, i can still access the file. Please advise.
@ kissofdeath
Will this work also on similar video sites such as x-tube and other tube sites/videos.
Answered By 0 points N/A #87589
That software is exclusive only for YouTube videos.
Now if you want to save videos from other tube sites (particularly x-tube videos),
You may use this one
This is highly rated ( my personal choice lol).
Just copy and paste the link and that's it. Videos will automatically download. For this software, you may only download 1 video at a time, if you want multiple downloads at a time, then you need to purchase the software.
Also, I guess Firefox has an addons for downloading tube videos. If you are still considering reinstalling the Firefox, you may use this add ons for downloading videos from net
Answered By 0 points N/A #87590
If there is a file which you want to save, just copy and paste it on your desired folder. Do not just leave it on that folder for it will be deleted by the system as time goes by. Every time you will use the IE, the files on the temp internet files will be replaced by the newer files while the older files will be deleted, that's how temporary internet files work.
I agree with kiss of death, firefox has a special feature which allows you to download videos from youtube sites. You just need to download the add-ons and integrate it in your firefox for it to work. Actually, this is my default browser because of its unique features and add-ons.
Answered By 110 points N/A #87591
Thanks for the advice. I'll try to consider firefox, but for now I'm still happy with IE. Thanks a lot guys!!
