Need help how to install windows 7 on a Samsung galaxy tab.
I just saw in YouTube “Galaxy tab using windows 7”.
Need your help guys on how to install it?
Best Answer by Austin kelley
Answered By 0 points N/A #144893
1. Just copy the windows 7 files as image file on any computer with the name c.img.
2. Transfer it to your Galaxy Tab and install bochs apps. (bochcsd.txt along with BIOS software are available on Internet.)
3. Paste all these in a SDL folder. (You make a folder named to SDL. )
4. That’s all you have to do.
Answered By 10 points N/A #144894
Yes you can install windows 7 to galaxy tab.
First find Windows 7 CD and plug CD-ROM to your tab through USB cable.
When your tab is booting change the boot device to “CDROM” in BIOS settings because we need to boot the tab using Windows7.
Then you have to follow the instructions to install the operating system.
