Need help with HTML to iCAL conversion
I need help in converting html to icalendar. I have a personal calendar in html format that I need to share with some people, however their calendar application (Google calendar and Apple calendar) only reads a .ics extension. How do I go about converting html to icalendar?
Answered By 0 points N/A #196276
Hi Kristen,
You want to get software in which you can convert your HTML source coding into calendar so you do not worry about that you can get changer application after this application you can save convert any time your HTML source code into the calendar and for your further help I am giving URL ptf.com/convert/convert+html+to+ical/ your problem will be solve.
Hopefully this information will help you.
Thanks,
Raun Nelson
