Need help import mail thunderbird dans lotus
Hi experts ,
I have been informed that there are fruitful procedures to import mail thunderbird dans lotus ; and I am asking somebody' s patience to show me how doing it .
Regards
Hi experts ,
Regards
For enabling the import option you have to –
To learn the in depth process-
Hi there user:
First, go to the Import/Export Tools and download a copy of .xpi. Open Thunderbird and select Tools/Add-On. Click the Install button. And select the file that was downloaded. Click the Install Now. After its starts, navigate the Thunder Folder where you wished to import emails. Select ToolsImport/Export in mbox/eml from a directory menu and then click ok.
Thanks for asking.
Best regards,
Notifications
