Need Help In Compressing A Video File For Email.
I need to submit a video essay for a college application but the mail is not sending because the file is too big. I need help in compressing a video file for email.
The best way to compress a file is using the software called “Windows movie maker”. It is a default software in a computer. Just open the software and click on the file button in the menu bar. Then, click on the import button and then browse the computer to import your file. Then, drag your file to the timeline which is displayed on the screen at the bottom. Click on the file button again and click on save movie file. Proceed through the process of saving until you get to the section called “movie setting”. Click on the “other setting” option and choose the option called “video for broadband”. You will get the option to select the size you want. Choose the maximum size your email provider allows and then finish the save process.
