Need help to install software for my Web Cam
Hi Experts,
One of my friends installed Windows 7 on my PC. Now he is out of the city. During this installation I lost my webcam software. I am now unable to use my webcam. Can anyone help find out the Tiny Tech Webcam Software for Windows 7 and guide me the steps to install it.
Best Answer by Baker Mich
Answered By 0 points N/A #195607
You can try this: http://softwaretopic.informer.com/tiny-tech-webcam-windows-7-driver/.
This problem is quite familiar .I think your PC is infected with a virus. First, download it, then run the file. If you have any antivirus, please allow the .exe file. Otherwise, your antivirus may think the .exe file is a virus.
Answered By 5 points N/A #195608
Hi Beeky,
I can definitely help you find one for you. Please navigate to the following link to download your software.
http://www.fileguru.com/apps/tiny_tech_usb_cam_installer
Once you have downloaded your software just go to this saved file location. Right click it and click on “Run as administrator” on the many options appearing on the pop up.
Alternatively you can also go to MFG of your system. Search under support/driver once you enter in your webcam model and you will be able to see the specific driver for your webcam.
Hope this helps.
Thanks
Baker
Answered By 0 points N/A #195609
Hi Beeky,
I can help you find the best webcam software for your Windows. You can get all Tiny Webcams' for any OS from a site. Just visit below link and get your software free. After downloading one run/install in your PC. I think you can easily install it yourself.
http://www.all-driver.com/search/tiny%20tech%20120
