Need help to install visual 2008 ubuntu
I am going to use Ubuntu operating system I want to install visual 2008 but i don,t know how i an do it please help if any body know about visual 2008 Ubuntu please tell me how i install it.
Hi, Amanda Keterina
As you know, from Google you can find a lot of forums but the chance of getting the right solution depends on where you post your problems. We have so many different forums to install visual 2008 ubuntu.
So classifying and posting them on relevant forums is the best way to get your answer step by step.
I can suggest you some good forums, which are listed below:
https://groups.google.com/forum/?fromgroups=#!topic/ulteo-ovd-community-support/6MoJ8RBZwvg  ( go through this link and get all your answers)
Thanks. Â
Hi Amanda!
If search the web installing visual 2008 ubuntu, you will see many forums and site to download. I will help you to install visual 2008 ubuntu. I will share with you the safest site to install. I will also share with you how to download. You can learn how to download in this link
https://itstillworks.com/open-ashx-file-8637982.html
In order to install it, you will need to use Wine. For more information, you can look at the URL below:
https://appdb.winehq.org/objectManager.php?sClass=application
