I need help in installing Defender Malware on my Mac OS X. I would also like assistance in uninstalling LANDesk from a Mac and move the address book from my old Mac to the new one.
Also, is it possible to state the reason for removing the Keyboard.
Setup Assistant feature from Mac OS 10.6.7?
selimuk
Need help in installing Defender Malware on my Mac OS X
For those infected with the MACDefender malware, the following steps are recommended:
1. Open Applications > Utilities > Activity Monitor and quit any processes linked to MACDefender.
2. Delete MACDefender from the Applications folder.
3. Check System Preferences > Accounts > Login Items for suspicious entries
4. Run a Spotlight search for "MACDefender" to check for any associated files that might still be lingering.
Unistalling The LANDesk:
1. Copy the file "uninstallmacagent.sh" from the ldmain share on the core server to the local Macintosh machine.
2. Open a terminal window and change to the directory that uninstallmacagent.sh is located.
3. Change the execute settings on the file uninstallmacagent.sh using the command "chmod +x uninstallmacagent.sh".
4. Execute the file by running "./uninstallmacagent.sh.".
To transfer your address book:
Open Address Book and go to File > Export > Address book archive
Save the archive on your desktop
Send the archive [.abbu] file to your new computer [via email, Bluetooth, network, etc.]
Open Address Book on your new computer and go to File > Import
Navigate to the .abbu file you saved and it will import all of your contacts
Make sure that your keyboard is not paired with any other Bluetooth device.
In any event, a Bluetooth device may be paired with only one thing at a time.
selimuk
To unistall the MACDefender malware, the following steps can be followed.
First of all go to Open Applications > Utilities > Activity Monitor and close any processes linked to MACDefender.
Than go to the Applications folder and delete MACDefender.
After that go to Check System Preferences > Accounts > Login Items for suspicious entries
At last Run a Spotlight search for "MACDefender" to check if there are any associated files that might still be lingering.
Uninstalling The LANDesk:
To Uninstall The LANDesk follow the following steps
Than Open a terminal window and change to the directory that uninstallmacagent.sh is located.
After that Change the execute settings on the file uninstallmacagent.sh using the command "chmod +x uninstallmacagent.sh".
Al last Execute the file by running "./uninstallmacagent.sh.".
make sure that your keyboard is not paired with any other Bluetooth device. In any event, a Bluetooth device may be paired with only one thing at a time.
