I'm trying to install a game onto my laptop and it keeps hanging up. I have tried removing the game and reinstalling, but no luck. I'm wondering what other options I have to get this to work other than just not installing it at all! Your advice is appreciated. Thank you.
Need help installing a game
You have several options, May be your copy is corrupted or something, So you should re-download it, If this doesn't work try installing as admin. By right clicking on the game installer, And then choose install as admin, You should also try to do a clean installation by cleaning up the registries, If you have a gaming pad, USB mouse or keyboard, Disconnect it, And uninstall its drivers, As some drivers may be conflicting with the installation process.
