Need help with java development
hi guys I have a problem regarding to java,is their any way to use multiple inheritance in java,because I need to inherit from two different classes
Hello Emerald,
I have read your concern regarding multiple inheritance in Java. As what I have understood, you wanted to know if it’s possible to use multiple inheritance in Java from two different classes. Is it right?
In the first place, java is designed for single inheritance; the creator omitted multiple inheritance per se. Its single inheritance doesn’t usually show a problem; when in fact, multiple inheritance could be a sign of bad design. However, developers found ways to successfully accumulate multiple inheritance in Java and solve the problem. In particular, separately rooted hierarchy with object as the definitive ancestor of all classes and Java solve this issue through C++ in multiple inheritance. Some people think that MI only causes chaos and has very little benefit. Nevertheless, minimal condition shows that multiple inheritance is very useful. It can also be benefited as a refinement of an interface.
I hope I am in the right track of understanding your concern and gave you a hand to fix the problem. I hope this information is of good help.
Good Luck!
Mali
Hello Emerald Hilton,
Notifications
