Need help KMSAuto activation error
I have installed KMSAuto to activate my Microsoft Office 2016 but during the activation process an error shows up “Found an Office 2013/2016 which does not support KMS activation. Press “OK” to run the utility “Convert Office RETAIL -> VL” or press “Cancel” to close this message. I need to remove this error message as soon as possible.
KMSAuto Net
Answered By 590495 points N/A #185181
If you used KMSAuto Net to activate Microsoft Office 2016 but instead this error is thrown, you are probably using an old version of the activator. Also, it is obvious in the message that it detected Microsoft Office 2013 or Microsoft Office 2016 which are not supported by the current version of KMSAuto Net.
This means the one you are using is very old and was created before Microsoft Office 2013 was developed. To activate Microsoft Office 2016 using KMSAuto Net, download and install KMSAuto Net 2016 v1.4.2. Supported keys for Microsoft Office 2016 and Microsoft Windows 10 have been added to this version. To use this activator, you need to install Microsoft .NET Framework 4.5.
If you don’t have it, go to Microsoft .NET Framework 4.5 Offline Installer.
Answered By 5 points N/A #310610
Agree with Sharath Reddy. You are using the old version of the activator. More addition according to my knowledge you are not blocking host in your windows. Try this tutorial how to block host in windows and then you need to install .Net Framework you can grab from the official Microsoft website. Now you need to download the the latest version KMSAuto Net 1.5.4 Portable Download. Make Sure you have done all the above 2 steps then run activator now.
Ping Me if you still have an issue i will assist your further.
