I need help experts. A problem with my microsoft cpu viewer. This is probably annoying; can you give me some ways on how to troubleshoot this problem? The viewer uses most of the cpu load. It will overheat. I really need to get this done. Suggestion is very much welcome. Thanks.
Need help on Microsoft cpu viewer?
Hello!
Are you annoyed with the Microsoft CPU viewer?
Make sure the temperature is good for the CPU. It starts to heat up when you start using it.
Other possible reasons are overloading loss of connection and over voltage.
You can also check the link for more details.
I hope you will get your answer here.
For further information on any issue, just visit this site again.
Hi Ruby,
    The computer will really overheat when there is a huge load on it. If working on a network, most of the time computer usage will be simultaneous. What you want to do to help lessen CPU overheating is to check the processes that are running in the background, if some are unnecessary then you can disable them to lessen the load. Another thing you can do is check the software that is running on the computer do they require so much graphics, heavy graphical program can take a huge load on the CPU usage. If disabling software or processes is not possible then you can invest on a computer fan or a better cooling system.
