bryan dowdy
40 points
Posted on - 08/22/2012
I am working with Microsoft project 2007(2010). There is a standard including form in it for an automatization project and now I want to change it. So i need two more options in TAB. One is "Predecessors" link with access database (added by const.) and another one is standard fields, access query which I added by himself.
Can it possible? Please share your opinion and suggestion.
Need Help in Microsoft project 2007(2010)
Yes it's possible. You can find the setting within the menu, start with Project>Project information. Fill it with your own project.
There should be a "Task Information Page" pop up, you can input your own data into it.
Hello Bryan dowdy,
Hope that my message finds you well.
Just to remind you that the predecessors field lists the task ID's, You can use the link tasks command on the edit menu
to link the selected tasks with finish-to-start dependencies and zero lag time. For the fields they contain one kind of information and is part of
table, Project 2007 has several kinds of fields:
-Task and task-timephased fields.
-Resource-timephased fields.
-Assignment and assignment-timephased fields.
Hope this solution will help you and please let me know if you need anything else.
Kind regards,
