Hello techyv,
I am using Microsoft Publisher 2007. My OS is windows vista. I want help from you to make mirror page numbering. I want to have page numbers at left margin on even-numbered pages and at right margin on odd-number pages. Is that possible in Publisher 2007?
Thanks in advance.
Need Help in mirror page numbering
Well Zachary Cashh,
It is a very common requirement in MS Publisher to number page for publishing book. Open your file and go to the view menu and click master page. Now go to edit master pages then select the start page as 1. Now click edit. Go to insert menu click page numbers here you will get option to set page number as you want.
Hope you find the solution.
1.Select View -> Header and Footer
2.(Optional) In the header, type identifying text at the blinking
cursor,
3.Insert Page Number button on the Header and Footer toolbar or
press Alt+Shift+P
4.(Optional) Select the page-number mark and format it as it would format
any other text
5.Click the Close button on the Header and Footer toolbar.
