I would like to mirror the video, HDMI input into my television and monitor both. I have purchased an HDMI splitter and I am able to split the HDMI input into two devices, but it looks like there is some problem with the DVI adapter in my monitor. Because in one monitor, it is showing error message "no DVI connected" and in the other one it is trying to display something but just flashing. When I connect HDMI directly to my monitor without splitting it works fine but not with splitter. Why is the splitter causing this kind of issue?
Need help in mirroring the HDMI input
Your issue could stem from many things, but focus on four areas: settings, brand, power, and damage. Inspect all equipment for damage (e.g., cracks, loose or missing parts, burns, leaks, moisture, etc.). Ensure that all devices are receiving the proper amount of power. Ensure that the brands of equipment are generally known to be compatible. Check the manufacturer websites. Also, review the A/V settings, drivers, and software on each device. Ensure they are properly configured and updated. Another option would be to try a different brand of product. Perhaps the splitter is simply not compatible or such a poorly made brand that it cannot handle this task.
