Need help in my Adobe Presenter
Hello to all,  Â
I have a problem. We have a project in school in which we need to make a movie presentation. I decided to use Adobe Presenter because I heard it was easy to use. So I downloaded it and it went smoothly. Here comes the problem, I can’t open it because, an error message constantly appears.
Adobe Presenter:
You will need to upgrade Adobe Flash Player before using the option, Press OK to
Install latest player or cancel to return your presentation.
I am using a Vista PC. I searched in the internet and found that this was because of an installation problem. I want to follow the instructions written. But is this a virus? Are there more ways to fix this? I need answers as soon as possible because I need to pass it next week.
Thanks!
