Need help with my blackberry curve where find bb msn color symbols.
Hello guys,
I have just owned a blackberry curve. I actually new to the blackberry user-interface. Where do I find bb msn color symbols in my blackberry? Thanks in advance.
Hello guys,
Good day Dudley Achan
When in the Blackberry messenger press the blackberry key, scroll to "edit my info" then use the symbol key to add icons to you name and if you click on the next page you will get the smileys. There are emoticons that you can also download, but i prefer this method.
You can type on the smiley next to the typing bar in Blackberry messenger, or Press the menu key
Then select add smiley.
Good luck with your Blackberry.
Hello DudleyAchan,
You can follow the instructions of Wagner. You can also download BB MSN color messenger for your Blackberry. Download beautiful BlackBerry MSN color symbols from online. Download these for free. So go to this link and download your desired symbols and have fun.
http://www.filebuzz.com/findsoftware/Symbol_And_Font_Blackberry_Messenger/1.html
Wonderful comments, guys, and I am grateful for your valuable information. Wagner regina, when I read your solution, I understood how to find BB MSN color symbols on my BlackBerry. Your process is very easy, and utilizing your method, I am able to use this option. I never knew about this before, and now I am able to enjoy it. Thanks once again, Wagner regina!
