Need help on my McAfee 2010 software
I am running my daily Malware Anti-Malware program and had deleted some threats. My antivirus is McAfee Total Protection 2010 and my computer’s operating system is Windows Vista 32bit. After having run that antimalware, I got an error message that says “YOUR COMPUTER IS AT RISK, CHECK FOR UPDATES.” I just followed what it said so I check my computer for some updates but I found out that my system is updated.
I had tried to submit this case to online McAfee support but I could not get into their website because it is not showing on the screen. My wife and I have the same program installed in our computer and she is having no problem with her antivirus.
I need your help so badly please.
