Need help with my tv tuner-basic procedure
I need some help with my TV tuner. I have recent bought a tv tuner with which I want to download some of the tv serials of my interest. However, I do not know the procedure to use. So I do not know where to begin with. Please someone one guide me through the basics which can be useful for me to as a beginner.
Alec Hughes
Answered By 40 points N/A #106763
HI there ,
I think you need help regarding TV tuner card and to record the TV series of your interest.
In the box with the TV tuner card there will be a quick start guide. Please read the carefully and you will get the Specific and basic knowledge of what TV tuner card is and how to use it.
After that insert the CD that you received by it and in that manuals folder will be there in that there will be PDF files or Readme files that will have more advanced stuffs regarding your TV tuner card.
Since there are different varieties of TV tuner card and you haven't mentioned ANYTHING regarding it here we can't help you specifically.
Good luck.
