Need help with need for speed undercover registry fix
Hey guys,
I recently bought need for speed undercover.
But the registry appears to be corrupt. Is there a need for speed undercover registry fix available anywhere?
I only just purchased need for speed undercover so I hope this registry issue can be fixed.
Thanks for the help in advance everyone.
Best Answer by Drake Vivian
Answered By 30 points N/A #173864
Hi there Jose V Lau,
Unfortunately, there is no quick fix you can download and install to fix your game. However, fixing your problem is quite simple thing to do and shouldn't take you much time or make you any troubles. Just follow the steps:
Click Start on your desktop and in the run field type regedit.
When the registry appears search for the Need For Speed Undercover under HKEY_LOCAL_MACHINE-SOFTWARE-EA GAMES.
Click on the Need For Speed Undercover.
On the right side the list of items will appear. Find g_PerformanceLevel and open it by double clicking on it.
When the little pop up appears, you will see that the value is 0. Replace it with 2, confirm the changes and close the registry.
Best regards,
Drake Vivian
Answered By 0 points N/A #173865
Hello!
If you bought the game, the best way to solve any kind of problem with it, is to notice the game provider, which in your case is EA Games. You can access the home site of the Company or the site specially created for your game. There you have access to their Help Center, which is always the best way to solve any kind of trouble you might have.
Before addressing to them, make sure all the steps have been followed when installing the game, and also that your PC and software can support the game requirements.
The link for EA Support Center is this one:EA Help Center
