Hey guys,
The Acer aspire one a0532h price is under $300, I see no other windows 6 cell battery for near that price.
I'm just wondering if it would run similar or if the extra money is worth it.
So is the ao532h all up a good deal?
Need help with Notebook Acer Aspire One a0532h price
Hi Ricky,
I understand your concern if A0532H is a worth deal of $300.00.
In my own opinion, Acer One A0532H is a good notebook since its 6-cell battery and its other specs. $300.00 is already cheap for a netbook right now but if you want to you can inquire the local store if there are any upcoming promos or go to trusted online websites such as Amazon or Walmart for cheaper prices.
It will serve you better if you buy the battery because PC works best with the hardware that they come with if you were to get a new battery it is possible that you might damage your computer. So you should definitely buy the battery even though it causes 300, you will have a much better future for your laptop if you do.
