Hi Experts,
Hope you doing good. I am student of School of Computer Science and working on my final project submission.My project "Online database school projects management system ". I am using Java as front-end, Please suggest me back-end to be used. Thanks
Need help in online database school projects management system.
Hi Kevin M Reinke,
Greetings!! You have got a very good project to work. For "Online database school project management system " you need a reliable, fast, easy to maintain backend yet cost as less as possible. When I am uttering this sentence only one database comes to my mind. The name of the database is MySql. Maybe you already have guessed it.
In a project like this always try to use MySql as backend which is compatible with most of the front end development language like Java.
Best of luck with the project.
I hope some of your headache has been removed.
Thanks & Regards,
DBD
