Need help purchased Nero 12 and Nero video
Recently, I purchased Nero 12 Software but I got the following error message when I attempted to start this software.
The error is saying some configuration problem as you can see below.
Can I get the proper instructions to start this software?
I want to use it properly so provide the solution to remove the error.
Thanks in advance.
C:Program Files (x86)NeroNero12Nero VisionNeroVision.exe
The application has failed to start because its side-by-side configuration is incorrect.
Please see the application event log or use the command-line sxstrace.exe tool for more detail.
