Need help to reduce the size of a video
Hi guys ,
I have created a 3-D video using Adobe After Effects CS5 , but the size of the video is very big ,
I want to reduce it's size without affecting to video quality ,
Please tell me how to do that.
Hi guys ,
Hello Anna.
It depends on the file format of the video you created.
I can recommend a freeware video conversion tool called Freemake Video Converter Click Here . Â
It supports all the formats that Adobe After Effects CS5 can create plus more:
3GP, 3G2, AVI, WMV, MKV, MPG, MP4, SWF, FLV, MOV, TOD, AVCHD, DV, TS, MTS, RM, QT, etc.
It can output to the following formats:
3GP, MP4, AVI, WMV, Matroska, DVD, FLV, SWF, MPEG, Blu-ray, and MP3.
Aside from being a very powerful tool, it is also very easy to use even for beginners. It has the option of limiting the size of the output video as can be seen in this screenshot:Hello Anna.
Hope this helps!
