I want to know about the 123 LogMeIn download procedure. I also want to know about this LogMeIn 123 software, what is the main purpose of this software? I want to know whether good support is provided by this software or not? Are the technicians worthy of providing good and timely solutions for different problems? Kindly provide some information about 123 LogMeIn software.Â
Need help regarding the 123 LogMeIn download procedure
Hi Corey,
You want to know about installation procedure regarding 123 Log Main I am giving details below for your help.
• Go to www.LogMein123.com support page will be displayed.
• The technician tells you a 6 digit code.
• Type the code in the box labeled enters your 6 digit code.
• Click starts Download you are asked to download the support Log Me In resue.exe applet.
• Click Run to download the applet it will take 15 to 30 seconds.
• Click Run to execute the applet.
• Once the applet is running wait for the technician to activate your session.
• You may be asked to give the technician permission to perform certain action. Click Yes to grant permission or No to deny
Hopefully this information will help you.
Thanks,
Raun Nelson
Hi Corey,
The best place to get this information is from the user guide provided by the site itself you can find a Starter Guide here Â
If you want to download pro version, you can download a pro user guide hereÂ
Both of which can be viewed online . Good Luck !
