I am getting an error message which says ‘Windows cannot open the rundll32.exe.Ffor opening this file; it is to be known that which program created this. To detect the program windows can search for online or manually can select.’ It is coming when I am clicking anything. I cannot get in to the Control Panel for removing the programs. I also tried the download, nothing has happened. I will be thankful for your help to get out of this problem.
Need help to remove the error in Windows
Hi Leonard,
To get over and resolve the issue, first thing you can try to do is to run a virus scan on your computer. There might be a virus lurking on your computer causing this. If your computer comes clean, then you can try to search for the rundll32.exe file on your computer. You need to copy and delete in on the folder c:\windowssystem32. If this still not resolves the issue you may need to follow the steps below:
Insert the Windows CD on the CD ROM drive on your computer.
Click on Start
Click on run
You need to type expand X:i386rundll32.ex_ c:windowssystem32rundll32.exe. Please do note that X stands for the letter of your CD ROM Drive.
You need to restart your computer.
Aristono
