Recently, we found out some SCCM workstation printer discovery issues, specifically systems are not being discovered nor populated correctly into the SCCM from the AD. Our AD has one domain, and our SCCM has one site. All workstations show up in the “All Systems” imaging but they do not have an assigned domain or site code. They also do not follow the correct collection as per our query set. All the SCCM components are properly installed and enabled in the workstations. Anybody got an idea how to remedy this?
Need help for SCCM workstation printer discovery issues
Hello.
In order to solve your problem, use delete special from a collection and run an AD system discovery. This way all resources in the collection will be erased and the clients from the AD will be brought back without installing a client.
Please note that if you perform this on a collation with the clients, you might run into another problem.
Hi
The step for SCCM to manually add a workstation
1. Open the system center to configure the manager console.
2. Computer Management have to expand
3. Once you already on in the computer management > Right click on to the collection group
4. Membership Rules tab click the computer icon
5. Then click next
6. Resource calss/System Resources
7. Attribute name or select name
8. Enter the name of the workstation
9. Next Select all to finish
10. Right Click on the Workstation-testing and select update collection membership
then you select ok to start the process to update the process to be used when its done
